probleme xmule
23/12-2004 à 12:02bonjourd,
Oui j'ai encore besoin d'aide je sais suis chiant mais c mon premier linux et métrise pas encore tout a fait [:D]
Bon voila g telecharger Xmule decompresser lance le fichier configure dans la console et toues ces lignes aprasent:
checking for g++... g++
checking for C++ compiler default output file name... a.out
checking whether the C++ compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking for gcc... gcc
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ANSI C... none needed
checking how to run the C preprocessor... gcc -E
checking whether make sets $(MAKE)... yes
checking for a BSD-compatible install... /usr/bin/install -c
checking for msgfmt... /usr/bin/msgfmt
checking for gmsgfmt... /usr/bin/msgfmt
checking for xgettext... /usr/bin/xgettext
checking for msgmerge... /usr/bin/msgmerge
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking for ranlib... ranlib
checking for strerror in -lcposix... no
checking for egrep... grep -E
checking for ANSI C header files... yes
checking for an ANSI C-conforming const... yes
checking for inline... inline
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for off_t... yes
checking for size_t... yes
checking for working alloca.h... yes
checking for alloca... yes
checking for stdlib.h... (cached) yes
checking for unistd.h... (cached) yes
checking for getpagesize... yes
checking for working mmap... yes
checking whether we are using the GNU C Library 2.1 or newer... yes
checking whether integer division by zero raises SIGFPE... yes
checking for unsigned long long... yes
checking whether the inttypes.h PRIxNN macros are broken... no
checking for ld used by GCC... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for shared library run path origin... done
checking argz.h usability... yes
checking argz.h presence... yes
checking for argz.h... yes
checking limits.h usability... yes
checking limits.h presence... yes
checking for limits.h... yes
checking locale.h usability... yes
checking locale.h presence... yes
checking for locale.h... yes
checking nl_types.h usability... yes
checking nl_types.h presence... yes
checking for nl_types.h... yes
checking malloc.h usability... yes
checking malloc.h presence... yes
checking for malloc.h... yes
checking stddef.h usability... yes
checking stddef.h presence... yes
checking for stddef.h... yes
checking for string.h... (cached) yes
checking sys/param.h usability... yes
checking sys/param.h presence... yes
checking for sys/param.h... yes
checking for feof_unlocked... yes
checking for fgets_unlocked... yes
checking for getc_unlocked... yes
checking for getcwd... yes
checking for getegid... yes
checking for geteuid... yes
checking for getgid... yes
checking for getuid... yes
checking for mempcpy... yes
checking for munmap... yes
checking for putenv... yes
checking for setenv... yes
checking for setlocale... yes
checking for stpcpy... yes
checking for strcasecmp... yes
checking for strdup... yes
checking for strtoul... yes
checking for tsearch... yes
checking for __argz_count... yes
checking for __argz_stringify... yes
checking for __argz_next... yes
checking for iconv... yes
checking for iconv declaration...
extern size_t iconv (iconv_t cd, char * *inbuf, size_t *inbytesleft, char * *outbuf, size_t *outbytesleft);
checking for nl_langinfo and CODESET... yes
checking for LC_MESSAGES... yes
checking for bison... bison
checking version of bison... 1.875, ok
checking whether NLS is requested... yes
checking whether included gettext is requested... no
checking for GNU gettext in libc... yes
checking for wx-config... /usr/bin/wx-config
checking for wxWindows version >= 2.5.3... no (version 2.4.2 is not new enough)
checking for wx-config... (cached) /usr/bin/wx-config
checking for wxWindows version >= 2.4.2... yes (version 2.4.2)
checking if wxWindows was linked with GTK2... no
checking for gtk-config... no
checking for GTK - version >= 1.2.0... no
*** The gtk-config script installed by GTK could not be found
*** If GTK was installed in PREFIX, make sure PREFIX/bin is in
*** your path, or set the GTK_CONFIG environment variable to the
*** full path to gtk-config.
checking zlib.h usability... yes
checking zlib.h presence... yes
checking for zlib.h... yes
checking how to run the C++ preprocessor... g++ -E
checking cryptopp/sha.h usability... no
checking cryptopp/sha.h presence... no
checking for cryptopp/sha.h... no
checking for main in -lcryptopp... no
checking whether pure GTK code should be ignored....
checking whether progress bar drawing should be disabled.... no
checking for ANSI C header files... (cached) yes
checking for sys/param.h... (cached) yes
checking arpa/inet.h usability... yes
checking arpa/inet.h presence... yes
checking for arpa/inet.h... yes
checking fcntl.h usability... yes
checking fcntl.h presence... yes
checking for fcntl.h... yes
checking for locale.h... (cached) yes
checking netdb.h usability... yes
checking netdb.h presence... yes
checking for netdb.h... yes
checking netinet/in.h usability... yes
checking netinet/in.h presence... yes
checking for netinet/in.h... yes
checking sys/socket.h usability... yes
checking sys/socket.h presence... yes
checking for sys/socket.h... yes
checking sys/time.h usability... yes
checking sys/time.h presence... yes
checking for sys/time.h... yes
checking sys/timeb.h usability... yes
checking sys/timeb.h presence... yes
checking for sys/timeb.h... yes
checking sys/resource.h usability... yes
checking sys/resource.h presence... yes
checking for sys/resource.h... yes
checking for an ANSI C-conforming const... (cached) yes
checking for inline... (cached) inline
checking whether byte ordering is bigendian... no
checking for off_t... (cached) yes
checking for size_t... (cached) yes
checking whether time.h and sys/time.h may both be included... yes
checking whether struct tm is in sys/time.h or time.h... time.h
checking for working memcmp... yes
checking return type of signal handlers... void
checking whether lstat dereferences a symlink specified with a trailing slash... yes
checking whether stat accepts an empty string... no
checking for strftime... yes
checking for floor... no
checking for ftruncate... yes
checking for gettimeofday... yes
checking for inet_ntoa... yes
checking for memchr... yes
checking for memmove... yes
checking for memset... yes
checking for mkdir... yes
checking for putenv... (cached) yes
checking for select... yes
checking for setlocale... (cached) yes
checking for sqrt... no
checking for strcasecmp... (cached) yes
checking for strchr... yes
checking for strdup... (cached) yes
checking for strrchr... yes
checking for strstr... yes
checking for strtoul... (cached) yes
checking for getrlimit... yes
checking for setrlimit... yes
checking for compiler with PCH support... yes
configure: creating ./config.status
config.status: creating Makefile
config.status: creating src/xmule.make
config.status: creating intl/Makefile
config.status: creating po/Makefile.in
config.status: creating xLibs/DynPrefs/DynPrefs.make
config.status: creating xLibs/xrc/xrc.make
config.status: creating config.h
config.status: executing default-1 commands
config.status: creating po/POTFILES
Et maintenant je doit faire quoi pour utiliser xmule? et si quelqu'un connait un overnet 0.52 pour mandrake 10.1 je suis preneur
merci !!![:D]
[url=http://fr.profile.xfire.com/scottynou]image[/url]
24/12-2004 à 12:13Après ./configure, tu peux essayer make puis make install pour finaliser l'installation.
henryII
probleme xmule
24/12-2004 à 12:57ok je teste
24/02-2005 à 14:15Vue que tu es débutant, je te conseille de prendre le fichier d'installatin sous forme de paquetage (*.rpm, ou *.deb), comme ça tu ne te prendras pas la tête pour le lancement du programme.
Si tu utilises une distribution basée sur Red Hat par exemple (Red Hat, Suse, Mandrake, Fedora Core...), je te conseille d'aller sur le site http://rpmfind.net et dans la zone de recherche tu tapes ce que tu veux, par exemple amule (c'est un client edonkey) et tu auras une version correspondant à ta distribution, que tu pourras installer aussi simplement qu'un programme sous Window$...
Bonjour. Je viens de découvrir votre site. Je le trouve très bien, magnifique... Bref j'aimerais recevoir des astuces et autres concernant windows 9X/NT/Me/2000/... en particulier et l'informatique en général.
Mes encouragements.
24/02-2005 à 18:55un peu tard lol mais merci d'avoir repondu je ne trouve pas de paquetage et depuis j'ai evoluer avec linux et j'arrive a maitrisé maintenant c'est bon merci de ta réponse quand même ;)
probleme xmule
24/02-2005 à 20:14Configure urpmi :
easyurpmi.zarb.org/?language=fr
Et écris : urpmi amule
axac
Merci de vous Identifiez-vous ou de créer votre compte
