Choisir une tablette graphique pas cher ?
elements2788 elements2788
1 contribution
Membre depuis le 08/11/2018
Envoyé le 08/11/2018 à 05:35 Modifié par elements2788
The Best Vacuum Cleaners For Your Home
For a long time, vacuum cleaners have replaced the old-time brooms for its powerful and thorough cleaning performance. With vacuum cleaners, cleaning is no longer that tiring and exhausting chore, which is why this modern cleaning device has been gaining popularity among all households.
That being said, getting a decent vacuum cleaner can get tricky and tiring sometimes. With the vast options available on the market, there would be many researching and skimming through reviews required to know which is the best vacuum cleaner for yourself. Don’t sweat it! We’ve prepared here the best vacuum cleaners reviews to save you the time and hassle.
Top 5 best vacuum cleaners
Best upright vacuum cleaner: BISSELL Cleanview Swivel Pet Upright Bagless Vacuum Cleaner 2252
For any fur parents out there, the BISSELL Cleanview Swivel Pet Upright Bagless Vacuum Cleaner 2252 might be the best vacuum cleaner for home you’ve ever had. With a Triple-Action Brush Roll, the device works incredibly when it comes to removing embedded dirt and pet hair on any kind of surface, especially carpets. The triple-helix brush roll allows the 2252 model to loosen, lift, and remove pet hair without having it tangled on the brush, while ensuring no damages like scratches to the floors.
Featuring Scatter-Free Technology, the BISSELL Cleanview Swivel Pet has unpowered side brushes to trap the dust once it’s in the suction inlet, lessening debris scatter during the cleaning session. These side brushes can also pick up dirt and debris from one side to the other with the Edge-To-Edge Cleaning function, allowing users to move the device along the edges or corners for thorough cleaning.
The best thing about this 2252 BISSELL model is Multi-Cyclonic Filtration, which separates small and large particles to prevent suction loss due to the filter being clogged. This Multi-Cyclonic Filtration will keep the fine-mesh filter free of dirt particles for a long-lasting, powerful suction performance. To top it over, not just this filter, every part of the device aside from the motor, is washable under the faucet, hence hygiene.
Pros:
  • Remarkable cleaning power
  • Lightweight design
  • Swivel steering for effortless cleaning
Cons: Quite loud during operations.
Best robot vacuum cleaner: eufy BoostIQ RoboVac 11S (Slim)
Among the smart robot vacuums available on the market nowadays, eufy BoostIQ RoboVac 11S (Slim) has all that best-in-class functions of the best vacuum cleaners in the world.
First thing first, the model has users impressed by its quiet operation similar to a microwave. With its 55dB noise level, users can enjoy a quiet, peaceful time while still having their house cleaned.
The eufy 11S features BoostIQ technology that detects when the cleaning task needs a stronger operation to enhance the suction power accordingly, The technology allows the 11S slim model to increase suction power to 1300Pa within 1.5 seconds, hence fast adjustment. Besides, the device can work for 100 minutes straight per charge to ensure a long cleaning period.
➽➽➽ Read The Article: What is a vacuum cleaner - Top rated vacuum cleaner
Speaking of convenience, this robot vacuum cleaner integrates multiple cleaning modes and a pre-set timer so you can easily set the device for automatic cleaning on various surfaces.
The most significant advantage of robot vacuum cleaners is their compact and lightweight design that allows them to move around the house easily for a comprehensive clean. Likewise, this eufy RoboVac is designed to slim down to 2.85-inch thin, allowing the device to clean under low-hanging furniture at ease.
Pros:
  • Quiet cleaning operation
  • Sleek and slim design
  • Powerful and long cleaning time with just one charge
Cons: Dust bin is limited, so you have to empty it frequently.
Best canister vacuum cleaner: Eureka NEN110A Whirlwind Bagless Canister Vacuum Cleaner
If you are considering what is the best vacuum to buy, the Eureka Whirlwind Bagless Canister Vacuum Cleaner NEN110A can be the best option for you. With many great features, this model is among the best items in Eureka’s arsenal.
First of all, the vacuum cleaner weighs only 8.3 pounds, making it lightweight and easy to maneuver. Moreover, the compact design boosts flexibility and mobility, in which users can effortlessly clean various areas.
The best feature of this Eureka NEN110A is its snap-fit accessories, which can be locked into place with a snap for simple and quick set up. On top of that, all these components are all washable as well. Users can simply clean them under the faucet and let dry, hence the reusability for a long-lasting device.
Speaking of the accessories included, the vacuum has a cord with the automatic cord rewind function to quickly rewind the cords to avoid wrappings around you or furniture for the utmost convenience. Then it also comes with a large-volume dust cup of 2 liter that is easy to empty with the user-friendly one-button press.
Finally, the Eureka NEN110A features an incredible Cyclone Filtration System to filter the dust in sizes, maintaining effective and powerful suction performance.
Pros:
  • Snap-fit and washable components
  • Multi-surface cleaning for versatility
Cons: Many users complain about the short cord, which hardly reaches far places.
Best handheld vacuum: BLACK+DECKER dustbuster Handheld Vacuum, Cordless, 16V (CHV1410L)
For a more mobile and convenient option of vacuum cleaner, a handheld model is an excellent choice, especially for someone who is always on the go. In this category, the BLACK+DECKER dustbuster is among the top rated products.
With a comparably low cost and user-friendly design, this is always among the best rated vacuum cleaners for anyone looking for small and affordable cleaning devices.
The model runs on a lithium-ion battery that offers strong and consistent suction power. On top of that, the device features Smart Charge Technology to fast-charge in 4-hour and lessen the energy used up to 50 percent. To enhance suction performance, the integrated cyclonic action prevents the filter from being clogged for strong suction. Moreover, its translucent and washable bagless dirt bowl and filter makes it easier for users to know when to empty and clean.
➽➽➽ Picked For You: https://thekinglive.com/shark-pet-perfect-vacuum-cleaners-reviews.html
The BLACK+DECKER CHV1410L model includes a rotating slim nozzle that comes with a pull-out crevice tool and flip-up brush. These components allow users to clean hard-to-reach areas and tight spaces, or various surfaces, including upholstery.
Pros:
  • Smart Charge Technology
  • Lightweight and compact design
  • Convenience integrated components
Cons: There are many complaints about its short battery life.
Wrap Up
Above are our top picks for each type of the best vacuum cleaners on the market. With this article, we hope you can now easily get the main features of some top rated products and narrow down your options. Now that you have enough information, it’s your turn to grab the best vacuum cleaner for the house.
mic69300 mic69300
Envoyé le 08/11/2018 à 11:21
Dans docs transmis , tu as 1 chat (en mauvais français) où tu peux poser toutes questions.
- prix débutant à < 50 € transport gratuit —> origine probablement asiatique.
- qui assure SAV ? Conditions ?
- qui assure le renvoi ? utilisateur ? fabricant ?
- prix du renvoi ?
